stockist of boulter buderaus boilers
29 Jan 2005
Does anybody know of stockist of these in the West Midlands area.
Spoke to PTS late this afternoon they said they will need order them. Also the product range they had was different to the one on butlers website.
PTS - say they have 500, 800 rangebut they weren't able to give me a price yet
Butlers website - 500,600 range- no mention of 800 range
Anybody got ideas of ball-park cost on these ( i know i shouldn't be asking 'how much' question)
________________________________
moderator
please note 9
I
Why do you want one of these specifically, PTS and Wolsely outlets have multitudes of boilers of all spec and qaulity, why pick one they dont have huh ?
I fit these boilers exclusively they are the best money can buy. A real engineers boiler.
I get City Plumbing to order them in by the pallet specially for me. PTS now want my business and are stocking one of each. They claim they can get one from the feeder next day.
I mostly fit the 50028C combi or the 60019r regular boiler. I don't bother with 24kw combis at all. I used to fit the 60028c but actually prefer the 500 which is cheaper. The only reason I would fit a different boiler is if I needed a combi with more hw output, but I try to get them to have a 19R or S with S plan and unvented cylinder instead.
My area is Scarborough so not useful for local information but I do know that pts can come up with the goods. Also flue extensions and bends and vertical kits are readily available. They do a great (probably the industries best) modulating programmable room stat which doesn't require any 230v connections so outside clutches of part p.
Don't hesitate, persevere.
Worcester digistats are RF, dont use them anymore due to part L and using Ideal Icos/Isar with either Honeywell CM67 or Drayton wireless, fek part p.
Good luck pvman when it's time to try and rake the aluminium oxide out of the ideal heat ex.
whats RF got to do with part L it will still provide an interlock. ?
Since part L moved off Worcesters due to greenstars being overly complicated, so moved onto Ideal Icos/Isars, so since part L dont use digistat as I dont fit a Worcester to fit one into, hope thats cleared up the confusion.
COG, most digistats require 240v connection so come under the umbrella of part P testing requirements but the one I was referring to has no 240v connection, works entirely off internal batteries and makes a no volts contact. It has to do with part P and Part L, because it is also the best practice method of control being that it modulates the boiler, and is a programmable room stat.
PVMAN I agree Worcester have become complicated. I just don't like the Ideal heat exchangers for accessability reasons and size (too small to get your hand in, unless you were a mini mechanic in an earlier life)
