Stop/Reset switch for pump question........
26 Sep 2007
Bedfordshire
Hi people need help basically with a stop / reset switch that im going to wire up in my father in laws garage to feed a water pump its the correct rated contactor to do the job its a Danfoss CIM 12a reset / stop button which was doing the same job somewhere else but unfortunately when they disconnected it they didnt note any connections down so now im left with this theres no circuit diagrams with it either and no information on the side which is of any relevant use for wiring it and basically contactors are a alien to me ive supplied pics of just hoping someone can point me in the right direction the links have been left in tho from its previous use ..........Oh and the water pump is a single phase pump just want this to drive it
The photo on the right shows the top left terminal saying 264 v 60 hz and the top right says 220v 50 hz and you can see how these were linked quite confusing really
cheers hope someone can help
[/img]
The terminals you speak of are for the contactor coil. What causes the pump to start (contactor to energize) and stop (contactor de-energize)?
I take it these are the only 2 terminals for the coil?
cheers for your response spark123 erm forgive me for sounding like a complete novice but I dont understand completely if they are the only 2 terminals for the coil or not I understand how the contactor works but ive never wired one ever and on the side of it it doesnt say which terminals are for the coil ........I just need to know what terminals to wire by incoming feed to and supply load to, obviously the earths to the earth tab but these links which were in there to begin with have confused me should I remove them ?
thanks again for yer help im a qualified spark but as I said never done anything with contactors in my short career so far and really want to understand this side of electrics and improve myself as its also a very important side of our works .....
The terminals you speak of are for the contactor coil. What causes the pump to start (contactor to energize) and stop (contactor de-energize)??
If you could answer Spark123's question it would be a big help. Are there push button switches on the front of the contactor (i.e. it's a DOL starter) or was it switched remotely?
Oh ok sorry it just has one red stop/reset button on the front i havnt been round to the garage yet to have a butchers he dropped this into me yesterday I just rang him now hes using it for a pump to pump water into his garage as hes a mechanic im presuming itd be on continuously until he puts the stop button in ....Hope this is enough info for ya and your helps much appreciated
Is the stop button latching? I don't like the idea of this being the only control over the pump tbh.
just curious.
does your dad have a really big pump then? I am just wondering why it needs a contactor (unless he wants several stop buttons around the place)
This is the switch he supplied me says hes happy for it its only his garage out the back of the house would you say a start stop button would be better ? The pumps only a small enough pump he says I havnt checked the ampage of it yet .........All your comments are great im not entirely sure myself if this is best but lets just say he has short arms and long pockets in the spending department so wants to get away using this and me being the future son in law I want to be able to do the job so can I use this or not ? The stop button is one yes that latches do u mean stays in by that ?
i take it this is a normal houshold garage?
why cant he just plug in the pump as and when?
No its a big garage seperate from the house hes a mechanic does his own jobs at home the pump is down at the river about 20 feet from the garage and the pump will pump water into his garage he lives in the country so wants something permanent there .....I will be having a good look at this just want to understand the wiring of this stop button before I go take a look ......So can anyone help with this aspect thanks again
still cant see why he doesnt plug it in.
Taking water from a river you also need a licence if it is over a certain amount (sorry dont know what it is)
a contactor needs a supply. when the supply is started it pulls in some contacts (funny that) one set of contacts (or two) supplies what ever (pump in your case) the other set override what it was to start it in the first place.
to stop it a stop switch(or more than one) is wired in series with the supply to the coil
View media item 1645
sorry the sketch is a bit rough, but thats how its done.
obvioulsy i have left out fuses earth etc.
still dont see the point
i will leave you to guess which is start and which is stop
i wouldnt. sorry but your pictures speak a lot but say nothing.
i would be inclined to get a meter out and find the coil then and then take it from there (you only want a minimum of two pairs of contacts that go closed when coli energised)
The stop button should be the very first item in series in the control circuit, for safety reasons.
Regards
cheers for all your help dont worry ill be seeing exactly hwat needs to be done and if he can get away with just an isolator maybe instead as like you I dont see the point but thanks for your input much appreciated
