Hi all hope you can help i have removed two old storage heaters one large and one smaller i do not not know what wattage these were.I intend to replace them with a 3.4kw and 1.7kw in the same locations.The current switches are an isolation switch with neon light where 3.4kw will go and a 13amp fused switch where the 1.7kw will go. Will it be ok to wire the new heaters into the switches that exist already.Secondly in the main fuse box there are 15amp fuses used for the old heaters will this still be ok for the 3.4kw and the 1.7kw.Hope that makes sense will be grateful for any input.
