The storage heater is a Dimplex xms724n and the thermal safety cutout keeps operating. The heater heats up so certainly takes some charge before the cutout operates. Looking at the link below it appears the old cutout stats which are like limpet thermostats are replaced with a repair kit featuring a different designed stat.
http://www.storageheater.co.uk/dimpex/xl-xt/xms724n.html
Whilst I was checking the heater after resetting the cutout I put an ohmmeter across L & N, with the supply switched off, and measured the resistance which was about 18ohms. However no matter which way I turned the input charge control knob, the meter still read 18ohms. Also turning this knob there was no audible click as when the charge switches on/off like on the other storage heaters. The only difference with this heater is there is a room stat sticking out of the bottom of the heater which I assume is connected to the input charge controller. My query is how do these two, room stat and input charge control, interact with each other and should I still hear that audible click when the knob is turned? TIA
