Hi guys,
A very strange lighting question that hopefully has a fairly simple solution.
I've recently changed the light in the hallway to the below
http://www.bhs.co.uk/mall/productpage.cfm/bhsstore/976876
It is controlled by two, 2 way rocker switches.
As you can see - It has 20, G4 10watt bulbs.
I wired it up as described. (three lives together, Light Neutral to two neutrals, and Light Live to Switched Live). All earths to the earth terminal on the light.
Works fine, and if it's only on for a few mins, and I turn it off, then turn it back on, there is no problem.
I the light has been on for about 2 hours and i swithch it off a strange thing happens.
If i turn it on straight away, the G4 bulbs flicker then slowly light up, and come on.
If I leave it about 5 mins then they are dim for about 30 seconds, then eventually come on.
Any longer, and the the light doesn't come on at all. However, if i leave the switch on, then the light comes on after about 20 mins on its own.
There is a slight click at the light when I turn the switch off, but this doesn;t seem to effect it coming on or off.
I guess the question is, does it sound like there could be a lose connection in the wiring I done connecting the light?
Is this a common occrance with this type of light?
Could there be a problem with the ring wiring ? (there were no issues with the normal ceilling rose that was there)
Or is the light faulty ?
Appriciate that the above is not very clear but your thoughts would be appriciated.
Thanks.
Thanks.
