Hi everyone,
New year, new problem!
I have a strange lighting issue that i've never come across before and am not sure how to solve.
The upstairs of my house contains the following lighting components:
Bedroom 1: 5 x Mains downlights, 4 x small LV downlights (over wardrobes), 1 x 2 gang touch dimmer. Also 2 small wall lights individually switched.
Bedroom 2: 1 x pendant light, 1 x 1 gang touch dimmer
Bathroom: 4 x LV Shower downlights, 1 x LV Extractor fan powered from the lighting circuit, with Isolator switch.
My issue... For the last few weeks the bathroom light has been switching off the small downlights above the wardrobe! It happens both when the bathroom light is switched on or off but does tend to occur either when the bathroom light has been on for quite a long time of if it is turned on or off about 4 times in quick succession. No other lights area affected.
I should probably mention that its been wired like this for around 2 years without any problems until recently, despite nothing on the circuit being changed. I have checked to see if the points where the switch cables are wired up have worked loose causing a short of some kind but it's all fine.
Any ideas would be much appreciated.
