Hi all
I have recently installed a 6x6 feathered edged fence with 3x3x8ft postcreted 2 foot below ground with nails hammered in. The panels are held on the fence with 8 metal brackets each.
We recently experienced high winds and noticed that the fence was swaying quite a lot. I put some 3x3 offcuts and wedged them at an angle against each panel in the middle under the second slat. This stabilized the fence a lot, in fact it was a lot more rigid.
To permanently reinforce I am thinking of dropping some more 3x3x8ft posts in between the original posts and screwing the panels directly to these. However I might also put diagonal slats on the panels to make them more rigid as you would a gate and maybe add some stronger 2x4 across the top and bottom of each panel.
I could also put some angled 'lean to' supports that sit on concrete and support the fence on each fence somewhat like I did as a temporary measure in the winds, but fixed to a concreted grounding and to each panel, centred.
I am in a bit of a dilemma of which way to go for this. The fence is new and replacing or rebuilding is not an option.
Any advice or help is welcome and highly appreciated.
Kind regards
mick
Kind regards
mick
