- Joined
- 27 Jan 2008
- Messages
- 29,749
- Reaction score
- 3,688
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The Aldi multi-tool, is petrol, and you need the harness due to weight, the Lidi is battery, and for me the harness is too short, but since the machine is lighter I don't have a problem, I still have the old mains powered strimmer, and now I have a socket down the garden, no reason not to use it, but so much easier with battery powered, I don't bother.
But 40 volts is a lot more than many strimmers use, and I can with two batteries work for ¾ hour to an hour, and I have 4 batteries, by the time second set are discharged, I do need a rest, but putting the first two back in after being on charge for ¾ hour gives me a bit more, so around two hours before forced to have a break (battery charger does two batteries together) there are larger batteries in the Lidi range, but after 2 hours strimming I am about done in.
But with units only taking one battery, I can see a problem changing them all the time. Specially, if you can only charge one at a time.
