Stripping wood ceiling beams :(
18 May 2017
HI ,
I don't know what my beams are made of , please see attached, but they are covered in what I assume to be woodstain.
I've had two quotes to remove it via blasting , one at £1300 and one at £1500. They both said it was a one day job. I cant afford either !
The surfaces are rough. riven so I cant scrape it off, and advice please ?
thanks
I appreciate that the price sounds like (is) a lot for one day but you probably won't be able to diy to it unless you want to spend some time learning how to apply faux wood grain- in short, you apply a light base colour and then use graining rockers to apply a slightly darker colour.
There might be a reason why they were stained darker.
Sorry. I am a decorator but seldom work in houses like your yours.
HI ,
thanks
Do you know when the house was built and if the beams are original?
Blasting is a destructive, expensive, measure to strip back old wood.
Far better to use a chemical stripper and a tin of elbow grease.
You could lightly sand away a small corner to see how deep the stain goes.
150 years old and yes they are original. I just dont understand how you get woodstain out of a deeply riven surface with a scraper or sandpaper.
