Hi. I am looking to create a wall-hung bench seat in an alcove. The dimensions are 2060mm wide, 400mm deep. It will sit directly above a wall-hung unit which isn't strong enough to sit on. This seat can be invisibly supported at each end, and am thinking of a metal angle along the whole back into which the slab sits. I can't figure out a way to have a strong full depth support from the mid back to the front, due to the need for this slab to sit almost on top of the bench to make it look as one unit. If that makes sense?
Thickness can be anything from thin (20mm?) to 50/60mm.
I am looking for appropriate sheet material to create that bench seat, with minimal deflection/sag. It can be something with a nice wood finish, or something I can use and cover it with the same wood I am using for the floor.
Any ideas?
Any ideas?
