- Joined
- 1 Nov 2002
- Messages
- 2
- Reaction score
- 0
- Country
Can anyone suggest how to free a stuck (off) Drayton thermostatic rad valve? and/or does anyone know how they are put together? i.e. when you remove thermostatic capsule there is a round piece of brass held into the valve housing with a circlip. In the middle of this piece of brass is a small nut from which protrudes a pin about 1 - 1.5 mm in diam. I presume this pin operates the valve and is stuck. If I loosen the nut then water begins to flow and doesn't seem to leak out - is it safe to leave this nut loosened?
