stud wall
19 Sep 2003
I am just building a stud wall on top of some damp proof membrane. the wall will have some kitchen units on it but we dont know where we will buy the units from yet so my question is at what height do i put the horizontal stud onto which the wall units will hang? I purchased a new scaffold board to achieve this but we are still not sure.
help would be much appreciated.
regards
Not quite sure what you mean here.
Depending what units & where the fixings are, maybe you could plasterboards one side for the time being then fit the noggins on the other side of the stud wall to pick up the unit position.
If you use cabinet hanging rail instead of individual hangers you'll only need to know where the uprights are. If your cabonets are going to carry a lot of weight consider using L-brackets beneath the cabinets. These are installed with the wall arm hidden behind the cabinet
Scrit
Minimum fixings as follows
Verticals should be 400mm centres and horizontal noggins should be 1200 centres in order to fix plasterboard .
You can then put additional noggins in to suit
Average height for top of units is 2100 assuming 720mm high wall units. if you set the top edge of your scaffold board at this you should be well covered as you will have 225mm to play with.
Or as Scrit says use the continuous rail but you will have to notch the cabinet sides so they clear it.
Jason
