Currently ripping out the old floor in the kitchen and found some grey stuff in the room the kitchen will be extended to:
At the threshold between the two rooms:
Black floor is mastic on concrete. I think the grey stuff is a very thin layer of levelling compound which was put on before the beige vinyl tiles were installed, what do you guys think?
Either way, should I just rip out the beige tiles leaving the grey part and self-level the old black floor which is about 5mm lower?
If I was lazy and didn't want to level could I just use thicker tile adhesive for the black floor part?
And lastly should I be using the same acrylic primer used for tiling, under the floor leveling compound?
Of course I plan on scratching up the mastic a bit before priming with acrylic and adding leveling compound/tile adhesive.
Thanks for your help.
