- Joined
- 3 Sep 2016
- Messages
- 1
- Reaction score
- 0
- Country
I need some advice. I moved into a newly built block of flats in 2014. A year later and the communal areas, particularly the small entrance looks dreadful. The plaster and wood skirting do not appear to be able to sustain knocks without holes being dug out of the walls. The skirting looks like mere pieces of wood that are now mashed up on the corners. The corners of the walls have metal strips poking through where the paint has rubbed off and the walls cannot be wiped/washed. Two years in It is beginning to look like the entrance to a crack house. I understand that the redecorating cycle is 7 years! Goodness knows the state it will be in then.
Why is it looking so awful after such a short amount of time? Why in a purpose built block of flats can the communal walls and paintwork not be cleaned? Did the builder use sub standard material or not put on a final durable finish?
Comments grateful accepted.
