Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Looking in the catalogue, it doesn't appear to have an edge moulding. The worktop look square on all edges.
I will be fitting it myself, and although I've done "normal" worktops before, I'm not sure how mason's mitre joint will perform with the movement of a wooden worktop.
What do you think?
One other quick question..
before bolting the butt together, should the joint be sealed in any way?
I'm thinking that if water gets into the joint, the wood would expand.
Maybe I'm asking the same thing, but do the biscuits and bolts form the mechanical joint, or do you use something like PVA or clear silicone across the whole joint before finally bolting up?
Biscuits keep the two surfaces level with each other, bolts hold the joint closed.
I usually use a little clear silicon to seal the joint as this still allows for timber movement, you can apply a coat of oil to the worktop edges before joining if you want, let it dry before applying the silicon
