So, my dad is finally getting a summerhouse built in his garden, and looks like Ill be doing the wiring. Now its not one of those flat pack assembly kits things; its the real deal joiners, builders, etc. Before we go any further, I know this work is notifiable and he intends on getting his sparky mate to check it and sign it off.
So, he said he only wants one 2 gang socket (for tv and beer fridge) and 4 Led downlights? peasy ( I think), but breaking into the main consumer unit in the house from a new mcb aint an option as it would mean ripping up 5 floors to get to it.
So heres my plan:
There is a new extension(utility room) around 4m from the summerhouse that's ring runs from its own mcb in CU. On the ring there is a 1 gang socket powering a fridge freezer and a 2 gang socket that has never been used inside a cupboard that is on the main wall.
So, I'm going to remove the double socket, replace with a 13a RCD fused spur, travel out brick wall directly from here into an ip65 junction box using 2.5mm T+E. From Junction box, run 2.5mm SWA cable along garden wall to a 'garage' type mini consumer unit on the exterior wall of the summerhouse. From the CU, use 1.5mm T+E to feed 4 led downlights from 3a MCB and use 2.5mm T+E to feed a 2 gang socket from a 13A MCB(replacing the standard 16A) .
I was going to use an RCD spur in the house simply for protection from the cable run outdoor.
Thoughts??
So heres my plan:
Thoughts??
