sump pump
13 Mar 2010
London
I did post this on the electrics forum, but was suggested that I try you guys
Replacing a sump pump but would like to put it in a sump pump container (bucket) problem is I can't seem to find one anywhere?
It can't be bigger than 450 mm diameter.
Any body know where you can get them.
Or is there a suitable alternative
Why not use a large plastic bucket that has contained readymix cement??
I use a rectangular small water tank the type typically used as an F&E cistern (although these are not so easy to come by these days!!) :wink:
