- Joined
- 28 Dec 2020
- Messages
- 6
- Reaction score
- 0
- Country
We are in the process of moving house and currently have a Netatmo thermostat along with a bunch of radiator valves.
Our new home has Oil central heating and hot water.
There are two thermostats - One in the hall way and the other next to the boiler(which is in the garage).
This one has 3 wires; the yellow with red sleeve has 240 V mains (when the thermostat is off) the others don't have any voltage, but when the thermostat is on and calling for heat none of the 3 wires have any voltage.
The heating and hot water programmer is Danfoss CP715
The CP715 Danfoss does not seem to have any control over the thermostat (looks like the thermostat is completely independent for heating). When the thermostat is not calling for heat pins 2 and 4 have no power but then the thermostat calls for heat 2 and 4 have power.
Also, the terminal marked Neutral has 240V
There are two two port valves aswell.
All I want to do is replace the thermostat with a Netatmo or add Netatmo somewhere so that it controls the heating.
Any help would be appreciated.
