I need some advice. I want to use the loft space for storage and thinking of putting in a loft ladder for safer access. The loft floor is composed by 2x4" joists and they are about 1ft apart. There is a current 600mmx600mm opening. Ideally I want to have a timber folding ladder installed, but that requires a larger opening, thus cutting a joist or two (can't go the other way, the hall way is orient that the larger opening has to cut more joists). The roof construction is strange. It reminds me of the trussed rafter roof, but it is not exactly a "W" (I will post a photo when I get a hold to my camera). The total flooring area (including the not clear for standing) is about 30 square meters.
Here is my question. Is it safe to trim the joist in this situation? Is it reasonable to expect a 2x4" joist support the trimmer joists structures, the truss frame and additional storage? I will leave the work to a professional carpenter to do the installation, but I am worry if I should actually get a structural engineer instead.
Thank you very much.
Sigurd
Sigurd
