I am in the process of doing a loft conversion
I have installed a velux and now want to do the floor.
I have a 3 bed semi and want to add a useable room.
The house is a 1950's build.
It is a 'cut roof' and has the joists running width ways with purlins and binders X2 the full length. There are two struts coming off the purlins centrally that meet in the middle (at a small block in the floor) there are also a few hangers.
I want to strengthen the floor and board it.
The length of the loft is around 17ft.
What i want to know is can i run additional wood along side existing joists off the wall plate was thinking 6x2 or 8x2
This would consit of a joist of 15ft from each end off the wall plate that overlap in the middle over the beedroom wall below (as they do now)
- so the joists would not be running across the total width of the loft which is around 22ft -
I will also need to take out the struts (and binders) after adding additional strengthening. Was thinking of putting additional 6x2 times 2 bolted together under the purlins and adding verticle supports. the 6x2's would rest on the new 6x2 joists.
I am not adding a dorma or bathroom,.
I will be getting a permanent staircase fitted in due course.
I have the following already :
Perlins x 2
7x2 16.5 ft long (cut into wall at one end not attached at the other.
Struts x 3 (each side)
4x2 meeting in the middle at a block on the loft floor
Rafters x 14 (each side)
4x2
Binders x 2 (1 each side)
4x2 length just under 16.5 ft (not attached to the wall)
Joists
4x2 spaced about every 14 inches
23ft total length (width of loft) but laid as two lengths that cross over supporting wall in the middle of the loft. (approx 11ft each length)
Cross members x2 (one at each end)
2x4 11ft approx attached to rafters ( was 3 but i removed the middle one)
Strengtheners x14 (span the top of each rafter) - I fitted these recently
2x4 (approx 25 inches cut)
The joists rest in the middle of most of the loft on a structural wall and onto the wall plate (i.e. on top of).
Any advice would be much appreciated.
Perlins x 2
4x2
Joists
