I've lurked here for a long time but now is the time to ask a question
I tried "search" but couldn't find an answer so apologies if you see this question every other week.
I'd like to add a proper floor to the loft in my Edwardian mid-terrace house (a non-habitable loft space with a wooden loft ladder for access); the approx floor size is 18 x 18 feet. The photo below shows one of the four ceiling binder on top of the ceiling joists: one under each eaves end and two equi-distant in the middle of the floor space:
There is load-bearing wall in the middle of the loft space, that runs parallel to the purlins; on the ground floor it is two bricks wide but on the first floor it is only 1 brick wide. There is also a "proper" load bearing wall (the top of outside wall of the house) 4 feet from the end of the loft space.
The initial idea was to run floor joists parallel to the existing ceiling joists with the ends resting on the wall plates but I can see no way of running floor joists like that as the ceiling binders are in the way.
The other option that sprang to mind is to attach 7x2" (or similar) to the walls at each end of the loft space and using hangers run larger binders parallel to the existing binders, so the top of the new binder is higher than the top of the exisitng ceiling binders and so that there is a 1" between the bottom of the new binder and the ceiling joists (to prevent them from bearing down on the ceiling if the new binders flex). The number of new binders would be determined by tables.
I would then run floor joists across the new binders, parallel to but not touching the ceiling joists, with a binder as close to the each of the joist to act as a pseudo wall-plate (although the space between the purlin and eaves will be used for light storage so there would be much additional weight on the ends of the joists.)
Hope you're still with me
Given the width of the loft space (the width and length is about 18ft) this would require each new binder to be joined in the middle, as would the new floor joists, using the method show in the photo below :
An alternative might be to use I-joists (has anyone used them for this purpose and are they expensive?), although I don't think a crane could reach the house my front garden is about 6m and there are telephone cables in the way (if I were to get them craned in when I get the roof done):
Hopefully that made sense. Am I on the right track or is it not possible? Is there a better way to do it? I'm not planning on making a habitable room (I can't afford to get a staircase and dormer fitted) but I'd like the floor to comply with building regs if at all possible (even if I don't apply for them). Will the floor need Building Approval?
Ideas and suggestions very welcome
