suprima pcb
6 May 2008
Cardiganshire
could someone offer some advice on suprima pcb. went to breakdown. customer said having to reset on a reg basis now wont reset. had a look boiler not reseting. all lives in correct.overheat stat buzzing but no voltage to overheat stat. pcb? quite common ive heard but i just want to be sure that ive reached my conclusion right. make a fortune replacing this easy fault if i came across this make!! thank you
try doing a search before posting!!!!!!!!!
how many threads do you need before it becomes obvious how SH*TE the suprima is :?
Probably is the PCB but sounds like you need a new stat as well.
When you put the new PCB kit, wiring harness on, the old stat will probably fall to bits.
after ya fitted the new pcb you'll be going back a year later to change it again! the new one's cut out before up2 temp..
still like the suprima's tho :lol:
They only seem to do this on thermal stores! :roll:
