Op already said he was going to do the digging and filling himself.
I read the same, it was a comment regarding what seemed to be a suggestion that 700 euros was expensive.
What has the voltage got to do with it? 1.5mm is adequate for a few LEDs. 240volts is low voltage by the way so no transformer required.Go for 2.5mm, most garden lights are low voltage and have a transformer with a 3 pin plug, but it all depends on what type of lights you are installing.
700 euros to bury 70m of cable doesn't seem expensive to me TBH.
Read post 3. The €700 is not for the cable which he has already bought. It is for the electrician to install it.
Which at the moment equates to around £597 for 70 metres.
Try shopping around and the first thing I get is this;
https://www.screwfix.com/p/prysmian-6943x-black-3-core-1-5mm-armoured-cable-100m-drum/36101
Move up to 2.5mm and you get this;
https://www.screwfix.com/p/prysmian-6943x-black-3-core-2-5mm-armoured-cable-100m-drum/66142
You guys must have money to burn if you accept 700euros/£597 is a fair price for 70 metres of cable. The original idea was to only bury it below the drive and then lay it amongst foliage.
For future things which don't yet exist and may never exist, is far cheaper and easier to install ducting, so that whatever cable(s) are needed in the future can be drawn in if/when they are required.
[tongueincheek]Not a 13A socket on a lighting circuit, winston, surely?![/tongueincheek]I doubt you’ll be running a mig welder at the front! 1.5mm is more than adequate for a few LEDs. Even a 13a socket could be added to vacuum out the car.
Of course not. But if he is thinking of using 2.5 or even 4mm cable I doubt that it is a lighting circuit.[tongueincheek]Not a 13A socket on a lighting circuit, winston, surely?![/tongueincheek]
Maybe he's come to accept what he's often been told - namely that if there's a 13A socket being supplied by the ciurcuit, then it's not a "lighting circuit"[tongueincheek]Not a 13A socket on a lighting circuit, winston, surely?![/tongueincheek]![]()
Of course, he'll probably argue that its the OPD that matters, not what the circuit is called - but many may then question the wisdom of having 'a few LEDs' supplied (without any 'fusing down') by a circuit protected by a ≥16A OPD!
Kind Regards, John
That's what many people think/say, and seems to be the way that BS7671 looks at it. However, even if they used 4mm² or 6mm² cable [and were able to terminate that in the light fitting(s)], I suspect that a lot of people would be unhappy about connecting lights directly to a 32A circuit - citing, amongst other things, the 'ratings' of the lighting accessories (which I personally regard as fairly irrelevant).As you know John the OPD is to protect the cable not what is on the end of it.
