Swann camera power supply
16 Apr 2004
Cheshire
Hi
I have the swann NHD-885MSB cameras and I want to install the additional power supply for better night vision. can somebody tell me the voltage required and the pin size or better still recommend a power supply that will do the job.
many thanks
16 Feb 2011
Sheffield
? It’s not separate ir plus it’s an IP camera with power over Ethernet .... so would assume the Nvr would supply sufficient current to power this camera
16 Apr 2004
Cheshire
I'm getting ghosting images at night. If somebody walks past they look partly invisible and I read somewhere that connecting a separate power supply would sort this, also why is there a power socket at the camera ?
Cheers
16 Feb 2011
Sheffield
Ghost images ....sounds like the camera is using sense up to improve the image ...unfortunately this will cause a motion type blur ...the power socket is in case you want to power it locally and not use the power over Ethernet
16 Apr 2004
Cheshire
Sense up ? whats this, is it a setting that I can change on the NVR ? I'm still going to try a power supply so can you recommend one ?
Cheers
