Hi all! Could you please advise and assure me I'm planning to do the light wiring correctly?
I live in Switzerland (Zurich) and need to install two ceiling lights. The attached pictures are named accordingly based on what light fixing is supposed to be attached to what wires.
For the light fixing 1 - I'll connect the neutral blue to blue, ground green/yellow to green/yellow and the live wire orange to brown, right? My question here is, when you look at the light's white plastic box in which I connect the wires... There are for each L, N, and ground two holes into which I can put the wire from the ceiling. Should I put it in the same one (opposite) as the wire from the light or should I put it in the "neighbour" hole next to it?
For the light fixing 2 - I'll connect the neutral blue to blue and the live wire purple to brown, right? As the light fixing doesn't have a ground wire, I'll keep the green/yellow isolated with the white plastic cover at the end, as it is, and tuck it away back to the hole. Same question as above, to which hole within the L, N sections should I put it?
My last question is regarding those transparent plastic "connectors" visible on the Ceiling wiring 1_inside picture (used for the blue neutral wire) and on the Ceiling wiring 2_inside picture (used for the live purple wire) - what are those for and should I be concerned that in one case it is used for the neutral wire and in other case it is used for the live wire?
Thanks a lot in advance for your expertise
