One wall mounted light switch is causing the lighting circuit fuse on the consumer unit to blow. All other switches work fine. I noticed the switch was faulty so have changed it but the fuse still blows. Problems in changing the switch are that the wiring is old so the cables are black and red and the old switch isn't marked at all. So, I may have reversed he wiring but can't work out if this could be causing the problem to continue or even if I have the right solution. I've checked the other wiring as far as possible and it seems fine. The switch seems to be the key to it. Any info and advice is welcome.
