I was about to replace the two 2-way switches that control a ceiling light when I noticed that the mounting boxes are live - as indicated by touching with an electricians screwdriver! I would be grateful for any advice about this. Many thanks
Thanks for that, although it seems odd that none of the other switches in the house respond in the same way to the tester screw driver. I will arrange for a check with a multimeter. Thanks againjj4091 said:Mains tester screw drivers do not give reliable proof of something being live, you need a multimeter to know for sure.
Thanks for responding. There are definitely green sleeved earth wires connected to the back of the box, but the mains tester screw driver lights up when they are touched [accepting that this is not a totally reliable test.RF Lighting said:I suspect there is no earth to the backbox
I'm not confident with DMM so have called in a qualified electrician who will come on wednesday. He suspects there probably is not a problem, other than the mains tester screwdriver, but I need to have peace of mind!securespark said:Are you confident with a DMM?
If so, what is the voltage between live & earth?
RF Lighting said:There may well be an earth wire connected to the box, but I suspect there is no earth to the backbox.
The earth wire may not be connected to anything at the other end, or the entire lighting circuit may not have the earths connected.
stevesey said:DMM will probably read a voltage as well.
Yes, spot on! There was no earth connection on either switch, even though earth wires were connected at each switch. Earth wire now installed. Thanks to all!stevesey said:RF Lighting said:There may well be an earth wire connected to the box, but I suspect there is no earth to the backbox.
Sounds spot on to me, the earth is not connected at the other end and as it is running alongside the live wire a voltage is induced (will collapse if you try and draw any current). DMM will probably read a voltage as well.
Check the ceiling rose or junction box that the earth goes to to see if it is actually connected.
