I want to connect an ornamental garden water feature to the lighting circuit in a garden shed. It has to be the lighting circuit because that's all there is, run from a 6A MCB (without RCD protection) from the house CU. The water feature draws milliamps so I intend to put a 1A fuse in an FCU. I also want to be able to turn the water feature on/off so I would really like the FCU to be switched. Please could you tell me if there is such a device as a switched FCU with 30mA RCD? I don't want to fit a switched socket because then someone might be tempted to use it for something other than the water feature!
Thanks in anticipation.
