HELLO.
THIS IS MY FIRST ATTEMPT AT THIS SO LETS HOPE IT GOES OK.
I HAVE A PROBLEM WITH MY CENTRAL HEATING PUMP RUNNING CONTINUOUSLY, ALL THE TIME THE CENTRAL HEATING IS SWITCHED ON AT THE TIMER.
IT KEEPS RUNNING EVEN IF THE BOILER IS NOT RUNNING. I KNOW YOU HAVE A RUN ON ON MY BOILER FOR THE PUMP, BUT IT WILL STILL BE PUMPING 10, 15, 20 MINUTES AFTER THE BOILER HAS SWITCHED OFF.
WHAT I CANT WORK OUT IS, DOES THE BOILER GET A SIGNAL FROM THE ROOM THERMOSTAT TO SAY THE ROOM IS AT THE CORRECT TEMP. AND THEN SWITCHES THE BOILER OFF, WHICH SHOULD THEN ALSO SWITCH THE PUMP OFF (AFTER THE PUMP RUN ON TIME HAS ELAPSED).
IS THIS CONTROL BY THE 'SWITCHED LIVE' TERMINAL IN THE BOILER AS THIS SEEMS TO BE LIVE ALL THE TIME?
HOPEFULLY, ONE OF YOU KIND PEOPLE CAN PUT ME OUT OF MY MISERY AND EXPLAIN WHAT THE 'SWITCHED LIVE' IN A BOILER DOES.
MANY THANKS,
GARY
MANY THANKS,
GARY
