System Boiler
31 Jan 2006
Cumbria
For my heating & hot water, I presently have an indirect cylinder with header tank & pressurised. I am proposing to fit a new System boiler, pressurised & without any header tank but my plumber is saying that I need a different cylinder even thou it is insulated and in good condition. Is he correct or is he "beefing up" the job.
There is no reason or regulation to say you have to replace your hw cylinder. As none of us here have seen your existing cylinder we can only give info on your post :roll:
Have a new system boiler fitted and keep your hw cylinder. A mains unvented will give better hot water performance if fitted correctly to a large enough cold mains supply and you have at least 3 bar cold mains pressure and around 20 litres/min flow.
Many thanks. System boiler with existing cylinder seems to fit the bill and be more efficient.
It depends on the type of insulation on your old cylinder, if you have major work done on your heating system these days you're supposed to have the cylinder and the controls brought up yo current regs. I.E. fast recovery cylinder with factory fitted (sprayed on) insulation, trvs, roomstat etc.
I didn't know that dave, I thought it was a requirement of the regs. Then again I haven't looked at that blue folder thingy I was given since I did the energy efficiency course. :oops:
It is recommended because if you fit a new HE boiler and don't replace your old cylinder the extra 10-15% efficiency the boiler gains can be nearly wiped out by any scale formed on the coil in the old cylinder. If I remember correctly i think it is something like 10% loss of efficiency for every 1mm scale :shock:
No doubt one of our more technical colleagues on here can confirm this or put me right :wink:
This post prompted me to dig that blue folder out (about time), as far as I can make out it says basic practise to meet the regs is a factory lagged cylinder, best practice is factory lagged with a high recovery coil.
If its an old cylinder thats not even to the old BS regs (which were still rubbish) the coil may only be a single turn so the boiler will constantly cycle.
Agree with you sooey!
Corgi are you cidered up? Trv's everywhere according to CHeSS basic :lol:
Not yet I aint but I am working on it
and chess basic is trv's in all rooms used for sleeping
best pracrice is trvs in all rooms except the one where the interlock is to be located
Thought that as well if boiler being upgraded cylinder had to meet part L
that is my understanding as well,cly has to meet bs1566 to comply with part l.
It does :)
so when you upgrade a boiler the cylinder (if not part l comp) must be changed to
