hi thanks for that first time im attempting this they have trvs on them so i turn the control off but what do i do to the other end of the trv?
Stuart
With the TRV top off, fit a decorating cap - this keeps the valve fully off. Essential to stop the water flow! On the other end, turn the lockshield valve fully off. You can then drain the radiator down - catching the water in a shallow tray, and then remove it completely.
John
if you dont have the decorating cap , turn the valve off , drain rad into a builders rubble bag (easier to get around pipes and catch the water) then get a 15mm female iron blanking cap and fit it onto the open trv end.
