Taking Power From Socket For Light Switch
Oh dear. I don't think you are cut out for this.
Take the blue wires out of L2 and put them in a separate connector (as per the diagram) but connected to nothing else.
The CPCs (earths) should be sleeved green&yellow and connected together in the earth terminal - on the switch if it is metal or - in the back box if the switch is plastic.
Ignore the cable marked 'OUT'.
I tried this exact approach
No, you did not:
hi i put one brown in com one brown in l1 and two blues together in l2
That's not what that diagram shows.
You must understand before continuing.
But you don't, do you, and that's what the fundamental problem is.
You don't know the difference between live and neutral.
You don't know what a switch does.
You don't have the basic knowledge you must have to know what you are doing, nor the basic understanding of how the things you want to fiddle with work.
I'm not saying it's beyond you, I've no reason to think you couldn't learn.
No, you did not:
  • Folks
    I tried again as described and I am delighted that it works
    Thank you everyone for your help
