    Dismiss Notice
Taking power to the shed
Discussion in 'Electrics UK' started by fridgefreezer, 9 Oct 2010.
  1. fridgefreezer
    fridgefreezer
    1 Jun 2008
    61
    Thanks Received:
    Coventry
    Country:
    Hi there. Ok, following on from my post about the SWA abbreviation, here's the project that gives rise to that question.
    In short, I want to connect this
    To this:
    I am planning on using 6mm 3c SWA.
    The demand side of the project will be a few fridges/freezers and the occasional use of electric hand tools.
    There will be two lighting circuits with two fluorescent tubes, and six 13 amp double sockets.
    The three MCBs on top of the Wylex consumer unit date from another project, and so I am intending to replace them/check that they are applicable for my needs.
  2. Sponsored Links
  3. fridgefreezer
    fridgefreezer
    1 Jun 2008
    61
    Thanks Received:
    Coventry
    Country:
    Question.
    Regarding the SWA, is it necessary to run it inside a conduit, or just leave it as it is? The plan is to fix it to the floor adjacent to the main building on exit, then underground to emerge at the side of the shed.
    Thx.
  4. 1john
    1john
    3 Oct 2009
    3,351
    Thanks Received:
    343
    West Glamorgan
    Country:
    questions -
    why have you got an RCD upfront unit for the shed when you have no option but to have it protected by an RCD from your current board (if there are spare ways?
    Have you got a spare way in your current consumer unit?
    What has made you choose 6mm for the sub main, what calculations did you do?
    Why have you decided on having two lighting circuits with one light on each?
    You consumer unit for the shed only has two usable ways, where will you feed your socket circuit from?
    What provisions will you be putting in place to minimise distruption from your shed electrics tripping out an rcd in your house can causing you inconvenience?
    If you connect to either one of those RCD's in your main board then you will have trouble, should one trip all of your lighting fails, should the other trip everything else in the house fails!
    What type of supply do you have?
    What is the shed made from, wood, steel ?
    Does the shed have a water supply?
    Are there any exposed extraneous conductive parts in the shed?
    How much is LABC notification in your area?
    Are you aware of Part P ?
  5. Chri5
    Chri5
    19 Jan 2007
    4,289
    Thanks Received:
    391
    London
    Country:
    SWA has it's own protection so won't need conduit- just as well because there's no way you'd get it inside a conduit anyway.
    You shouldn't run any cable at ground level / on the ground, due to potential mechanical damage. Bring it up 300mm or so.
  6. Bodgeitandleggit
    Bodgeitandleggit
    15 Jan 2010
    1,676
    Thanks Received:
    33
    Yorkshire
    Country:
  7. fridgefreezer
    fridgefreezer
    1 Jun 2008
    61
    Thanks Received:
    Coventry
    Country:
  8. londonboy
    londonboy
    22 Feb 2009
    1,582
    Thanks Received:
    149
    London
    Country:
    Oh dear. :rolleyes:
  9. fridgefreezer
    fridgefreezer
    1 Jun 2008
    61
    Thanks Received:
    Coventry
    Country:
    What's wrong?
  10. Sponsored Links
  11. swingles
    swingles
    8 Oct 2010
    71
    Thanks Received:
    Cheshire
    Country:
    Is this a DIY assistance site?
  12. skenk
    skenk
    23 Oct 2007
    1,094
    Thanks Received:
    81
    Glasgow
    Country:
    No it's an electrical talk forum!
  13. swingles
    swingles
    8 Oct 2010
    71
    Thanks Received:
    Cheshire
    Country:
    Can anyone join in?
  14. OwainDIYer
    OwainDIYer
    5 May 2010
    4,534
    Thanks Received:
    694
    Stirlingshire
    Country:
    And, what provision have you made for when the RCD, either in the shed or the house, trips and leaves you in the dark without lights while power tools are still spinning down?
  15. swingles
    swingles
    8 Oct 2010
    71
    Thanks Received:
    Cheshire
    Country:
    And what provision have you made for rising sea temperatures causing flooding, or possible terrorist attacks, or the yellowstone park supervolcano going off, or the astroid striking the earth. Come on op - own up. You've made no preparation at all :rolleyes:
  16. RF Lighting
    RF Lighting
    31 Mar 2006
    19,993
    Thanks Received:
    1,354
    Leeds
    Country:
    Right, first things first, you either need to ditch the 6mm SWA an run in at least 10mm 3 core, or you are going to have to TT the supply at the shed, which is NOT a DIY job.
    Secondly, you need to ditch that consumer unit youve got for the garage end and buy something actually fit for the job. A 5 way metal clad board would be ideal.
    You need to install main protective bonding bonding from your water supply and any other extraneous metal work in your shed back to the new MET in your new CU.
    Then you need an electrician to split your meter tails and provide you with a non-RCD protected 50A metalclad switchfuse at your mains position to connect the SWA to.
    Once this is done, then you can maybe start to think about final circuit design for the shed.
  17. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,858
    London
    Country:
    It's not reasonable to make provision against those, particularly the ones that will end civilisation as we know it, and it does distract from the genuinely important things.
Loading...
Share This Page
