Tap in wooden kitchen worktop
16 Jul 2009
Hull
I have a tap to fit in a wooden kitchen worktop. I will drill the hole and seal the hole with clear silicone. Is it then ok just to relie on the rubber washer on the tap shroud to seal between the worktop and the tap (like usually do when install the tap in a sink). Or apply a bead of silicone here?
its worth mentioning
make sure you treat with oil or other Finnish around the sink and tap cutouts overdoing it a bit as the most likely to give problem areas
and for what its worth cutouts make fantastic matching chopping boards/pot stand and coasters
