Well luv,
I may have to turn of your water , so you may want to get the kettle on first, - only one sugar for me,
oh and just sign Me time sheet here ~ points to the dotted line~
just to say I was here at 11.00am.
its just that the company likes me to record where i am for insurance reasons"
~looks down at the tap and shakes his head mutting and drawing in a short sharp breath.~ "ssssssssssssss - this could be expensive love, - got any biccies to go with the tea? "
______________________________________________________-
Ok, you have to find out firstly if you have an isolator running up to the offending tap.
( An isolator, turns off the water supply to that tap. - they can be many shapes and designs. but, [ wished I could post a pic here to show you typcal examples].. some may just look like little red arrows ontop of a silver valve some are buttons, some are windy wheel thingies)
If you can't see where to isolate, then you need to drain off your hot water tank. ( I know you wont be able to open the bath tap to do it - but you can open any other hot water taps)
First. you have to turn off your COLD water supply where it comes into your house. ( that's because, when you empty your hot water tank, the cold water will just keep refilling it. ad infintum)
and, you MUST turn off your boiler.
( That's because there will be no water in the hot tank )
ok so far?
Recap:
Turn off boiler
Turn off cold supply (where it comes into the house)
Open hot taps.
___________________________________________________________
(While the hot water is draining from the tank. you could check if there's still enough water in the kettle....... - one sugar for me)
____________________________________________________________
now you're ready to undo the tap....
