Do you actually work on electrical installations?
Have you ever been faced with a loss of power at 10pm with kids in bed and a homeowner panicing about the freezer defrosting and the boiler not working?
It's great following the regs to the letter of the law, and in an ideal world that's what we'd all do, but unfortunately when you get out there in the real world doing real jobs for real customers, sometimes you have to use your judgement and not follow regulations.
All we are talking about is leaving a circuit off RCD, something which is permitted by the regs if the sockets sre for use by instructed persons, and you can instruct the homeowner to what is safe usage until the fault can be repaired.
Yes and i have been faced with this many times how about you?
Nobody is telling you that you must comply with the regulations (I assume bs7671?) We are talking about the EAWR (The law).
Your forgetting that this is not simply removing RCD protection from a healthy circuit its removing RCD protection from a faulty circuit (hence the reason why it was tripping).
In the worst case scenario if you are not able to find the fault then i feel isolating the faulty circuit and supplying a temporary socket if you must or use an extension lead for essential items is adequate.
I fail to see what your defence would be in accordance with reg 29 of the EAWR if someone was injured as a result of this faulty circuit.
Worst Worst Worst case scenario what do people do in the even of a DNO failure? I think compensation for loss of food etc would be a lot less than an electric shock etc compensation claim.
If you are unsure about this maybe you should ring your approve body and see how they feel about your thoughts.
