You'll be getting 45A as well if the voltage drop is anything notable.
An heater element is resistive - as the voltage decreases, so will the current consumption/wattage.
Wire is though. The longer the more so.An heater element is resistive - as the voltage decreases, so will the current consumption/wattage.
Typo.
Exactly, hence my ...An heater element is resistive - as the voltage decreases, so will the current consumption/wattage.
Eh? Can you explain that?
I think that probably warrants an even bigger "Eh?"Wire is though. The longer the more so.
How does that explain the current going up to 45A "if the voltage drop is anything notable" ??Typo.
I was just really considering voltage swings on the input coupled with restistive heat generation and voltage drops on the cable.
253V, actually ... and anything down to 216.2VI was quite surprised at the voltage swing guarantees electric companies give. Anything up to 260v.
It's a safety feature. If the cold supply goes away, any hot is shut off completely to avoid scalding or worse.From what you say, I guess they must work differently from that?
Thanks, that's a very interesting observation and, as so often seems to happen, makes me wonder to what extent theoretical arguments reflect, in practice, the real world.I have exactly this setup in my garden room installed by the builder. Instant water heater under the basin supplying both the basin taps and a mixer shower. It works really well. So we’ll in fact that it set me wondering why people fit expensive electric showers
Thanks, and many thanks for being one of the few people who is addressing and discussing the actual question I asked, rather than trying to give (in some cases confused and/or incorrect) advice about the wiring of a water heater which I definitely don't need!It's a safety feature. If the cold supply goes away, any hot is shut off completely to avoid scalding or worse.
If that's the case, then it indicates a mode of functionality different from what I had envisaged. I thought that what would cause the hot supply to be 'shut off' would be the outlet temp being above the 'set temp' (or a higher 'safety over-ride' figure), despite the mixer's best efforts to cool the output water by mixing it with cold water. However, you are indicating that such is not how they workWithout that, hot water at whatever temperature it was supplied at would be provided from it, which could be a very high and dangerous temperature.
I certainly wasn't 'expecting' (or intending) to do that. As I said, I just 'got myself wondering' (about what would happen with no cold supply at all) as a result of a comment I'd just found myself writing!If you were expecting to just supply hot to the mixer then forget it - not going to work.
Are you not perhaps being a bit pessimistic? Desirable shower temps are said to be 35°-40° (and definitely not much above 40°), so the hot supply temp would not necessarily have to be much more than about 47° or so - and, furthermore ....It's probably a total bust anyway, as an instant heater won't be able to provide water that's hot enough to mix with cold to give a suitable shower temperature.
See example specifications below - hot must be 12C more than the outlet temperature and suggested at 60C+,
I wonder how small this 'bare trickle' would actually be with a 10 kW heater producing water at about 47°. A 3 kW over-sink heater certainly provides far more than 'a trickle' of water at a temp at least as high as that. Don't forget that I'm not looking for something that would be desirable as a long-term thing but, merely a shower which 'works well enough to be 'usable' as a definitely temporary measure.... which isn't going to happen unless the flow from the hot heater is barely a trickle.
You've done a lot better than I have - since I've more-or-less failed to find particularly useful technical specs for any mixer valves!Other valves may vary, but these specs are pretty common.
I may be completely making this up, but I seem to recall reading that instantaneous water heaters were unsuitable for thermostatic showers.which they suggest are suitable for use with a manual (not thermostatic) shower mixer - one of which they also supply
In the Uk.253V, actually ... and anything down to 216.2V
Kind Regards, John
