Well, I'm now at the point of testing the floor will heat up as the screed has had plenty of time to dry out.
I've been trying to get some heat in the floor for 3 days now, but failed javascript:emoticon('
I think the problem is that it's Summer, so the air temperature is warm (no surprise there). I specifically waited until the warm spell we've just had came to an end and the temperatures fell a little as I couldn't bare the thought of the heating being on for a number of days!
I could do with some pointers, here's my heating setup:
- Vaillant ecoTEC plus 637 System condensing boiler
- Radiators throughout the house with thermostatic valves
- New underfloor heating in kitchen/sitting/dining extension (no radiators)
- Vaillant VRC 430 weather compensator & thermostat in the hallway (this is the only thermostat in the house, apart from the small weather thermostat outside)
- Thermostat on the UFH manifold (in the garage)
I'm aware that I need to crank up the heating slowly, day by day. Up until early this week, the thermostat on the manifold was on setting 1 of 5 and the hall termostat is usually set to 21 during the day and 15 at night.
I have seen the pump working on the manifold, so I know water is being pumped around the UFH. The problem I'm having is being able to turn up the heating enough to get warm/hot water into the UHF, which is fed the same water that is pumped around the radiators throughout the house.
Initially, I tried turning up the manifold thermostat bye a couple of notches to 3 and didn't touch the hall thermostat. However, this had no affect as the rest of the house is warm enough, so it's not often the boiler has to heat water and pump it around the heating system and when it does it tends to be luke warm (from feeling the radiators). So changing the thermostat on the manifold isn't acheiving anything as I believe it is the hall thermostat that is restricting the temperature i.e. keeping it low in the heating system. So, I opened up the manifold thermostat completely (to setting 5 of 5) and turned up the hall thermostat to 24 (from 21) assuming more hot water would be generated. This does happen from time to time as I can feel the radiators getting warmer, then hot for a short time, then cooling down.
Unfortunately, it appears the heating is so effecient that it isn't staying hot long enough to heat the screed up!
Next, I turned the hall thermostat to 26 degrees. Same thing, still not feeling any heat on the floor, although the house is definitely feeling warmer now and the radiators tend to be "luke warm" most of the time, so I've had to start closing off the radiator thermostats.
I've now got the hall thermostat upto 27 degrees and it's programmed to stay at this during the day and to use a backstop of 19 degrees during the night.
The maximum temperature reading I've seen on the hall thermostat is 24 degrees!!!!! It just doesn't appear to be getting warm enough. The hall radiator is quite warm but not hot, but it tends to cool, then warm a little etc. rather than staying warm all the time.
So, I'm now thinking I should rank up the hall thermostat to 30 degrees and see if I can't get some heat into the system in the hope this will start to come through the screed.
Am I doing something wrong? Any ideas?
I don't feel as though I'm really in control of how much heat will be pumped around the UFH, which worries me a little having read that it should be increased 5 degrees per day to max, then reduced by the same amount.
