They are reading 0
I guess this is bad? (excuse my ignorance, but I'm new to UFH and manifolds).
Try unscrewing the white caps for a start.
The three white caps are unscrewed and are just "sitting" in position. This is how the plumber left them.
How are you balancing the flows between the rads and the UFH?
For the purpose of testing the UHF I've had to turn off pretty much every radiator in the house by closing each of the thermostatic valves. Only the hall radiator has been left on, which is where the thermostat lives. 48 hours at 27 degrees was just too hot with the radiators on!!!! So, I guess this should allow all the hot water to be fed to the UFH.
Is there just the boiler pump or do you have a manifold (eg a low loss header) and separate pump for the rads in addition to that for the UFH manifolds?
There is a boiler pump and the one you see on the manifold.
