texecom 168 - get info to diy software
28 May 2012
I recently had a texecom 168 installed with 4 8xp zone expanders. (i have 11 motion detectors, 25 magnetic contacts and 2 smoke detectors).
Now i would like to be able to do the following on an external device:
- know the status of each of the detectors
- know if the alarm is armed (or even better know how it's armed: full or partial)
- know if there is an alarm (or better which zone - with the status i know what is tripped exactly)
- arm and disarm the system remotely
The external device would be a raspberry Pi or (if i have to keep waiting for it) my home server.
In the manual i found 2 ways:
- using a plug in communicator: i guess the comIP module of a pc-comm?
- using the digicom outputs: i have 5 times 8 outputs available and maybe i can use the "panel outputs" (1x5) also. (i would make a little pcb using PCF8574 's to get the info to i2c)
I guess that i am not the first one to try this, but it seems that i cannot find specific guidelines for this?
I think that the module is the best way, but which one? Or is the "output" way better?
com gsm elite you can text arm the system disarm, set part set it will text you when set, part set, and if the alarm goes off and you can text status via mobile and it will text back.
