Good afternoon,
I've got the Emergency Button on Texecom Connect App set to Panic Alarm rather than reset after arming (happy to explain how to do this as it's not in the instructions). I have recently installed a CCTV system and hope to have the option to trigger a full alarm manually in the event of seeing nefarious characters on the CCTV where they shouldn't be.
Am I right in thinking that I can set off the panic remotely via Connect?
In the event I did this, am I able to toggle the panic on / off via the button on the app? If not would I need to change the Emergency Button to reset (annoying that you can't have both enabled), or could I disarm then rearm, etc?
Thanks, appreciate you help.
p.s. obviously an external PIR system would be better but I don't currently have the zones / money / time to do this (I do have other perimeter components).
