Texecom Eleite Wireless 24
7 Dec 2014
Hi
I have been looking through the Wintex options for a users.
Having searched through INS 177 and 467 - I am unable to find what the following options do
Cst O/P 2.A-TAG
Cst O/P 2.B-CODE
Please can someone help.
Thanks scotsgraeme
I emailed Texecom support and they said
Cst O/P 2.B-CODE – If this option is enabled and the panel is armed and then the entry is started on the panel and the user enters the code this will give an error beep and indicate that a tag is required to disarm the system.
Funnily enough, I had asked a similar question just last week
//www.diynot.com/diy/threads/texecom-premier-24-code-not-allowed-use-tag.429499/
Cst O/P 2.A-TAG - will disable the use of Proximity tag to disarm a full arm entry (does not affect part set)
Cst O/P 2.B-CODE - will disable the use of code to disarm a full arm entry (does not affect part set)
If you look at the thread I posted, it also had the screenshots from Wintex showing how the option was linked
Thanks.
I just don't know how these got set.
I had two users with this setting.
But all sorted now because of the helpful people in this forum
