Cst O/P 2.B-CODE – If this option is enabled and the panel is armed and then the entry is started on the panel and the user enters the code this will give an error beep and indicate that a tag is required to disarm the system.
Cst O/P 2.A-TAG - will disable the use of Proximity tag to disarm a full arm entry (does not affect part set)
Cst O/P 2.B-CODE - will disable the use of code to disarm a full arm entry (does not affect part set)
If you look at the thread I posted, it also had the screenshots from Wintex showing how the option was linked
