No, I can't claim credit for that panel, its just a picture I found quickly to demonstrate the point.
Have fun.
Have fun.
3A MCB direct to the panel in twin & earth sounds ok to me. I'm not an electrician so follow your electrician's advice. You don't move the mains cable once its connected in the panel so it doesn't need to be flexible.
An appropriate and readily accessible disconnection device (e.g. an unswitched fused spur) MUST be provided as part of the installation.
The Com 2400 is useful to alarm companies who can use it for Remote Upload/Download, remote servicing & connection to monitoring centres. It can send text messages over the land line but this system is becoming congested & less reliable at peak times.Is the Comm 2400 a bit of a white elephant now (I have the GSM dialer as well, to be sure!)
If I may ask one qquestion...with the advice of the tamper being wired to 0v - is this needed for each PIR or just on the panel if testing with the bell box disconnected??
Battery backup will keep it going for a few hours (the length of time depends on the load). If you get an auto dialler/Com GSM/Com IP connected you can get it to signal mains failure by phone/text/email to let you know that the RCD has tripped and the beer fridge is also without power.Slight concern as it's dual RCD (no way to place on non RCD MCB) but I guess with a back up battery, I'm ok there too.
"Few hours!!![]()
The battery, by the way, is a 3.4ah 12v...
Sorry...one more thing (for now!). Although I've routed/am routing the six core alarm cable at right angles to mains and at least 150mm when on straight runs, it's inevitable due to the proximity of the CU and panel (underneath one another) that the cables are running past the CU - might this be a problem? It's only a short distance...possible (if necessary) to place a shield for this run, or will the CU case provide any interference protection??
