Hey guys
Just wondering if you could be so kind to give me some advice
I'm an electrician and have installed many texecom veritas models with no problems.
Just installed a premier elite and I'm stumped by the wiring?!
I'm used to wiring in a normally closed operation and by linking out the tamper wires to create a tamper circuit for the pirs.
I understand the premier is set up for eol wiring and can be changed to use normally closed.
If so, do I use the aux/fault connections as the tamper, as I would a veritas panel?
Cheers
Cheers
