Am I being thick here but if it's set to double knock someone opening the door wouldn't trigger the alarm would they? I thought that double knock meant the sensor had to be tripped twice - so on a door contact you would need to open the door then close it and open it again for it to trigger????
the premier 1 continuous activation for the double knock time or 2 activations within that time frame.
so whilst it may not give false alarms, it may not register you entering the building either if the above criteria isn't met its not a good idea long term short term it may stop the false alarms.
