    Dismiss Notice
The best Manual Mitre saw?
Discussion in 'Tools and Materials' started by wau5, 7 Aug 2017.
  1. wau5
    wau5
    6 Sep 2016
    157
    Thanks Received:
    4
    Country:
    I want to purchase a good quality manual mitre saw that is actually a good quality tool and can produce excellent results- it will be used for trim work mostly but also for some regular mitre saw usage when I will be working away from power outlet.
    I currently got a nobex champion 180 which supposedly is the top-of-the-range-stuff ,and quite expensive as well. I bought it because it got good reviews and people were suggesting it- but it's one of the worst quality tools I have ever bought and I regret that purchase everytime I use that tool. ( stuff that has already broken on it- 2x handles/one guide/both clamps/support piece )+ It doesn't cuts anywhere near square so it's only good for very rough cutting which defeats its purpose. Very good ideas - but very bad execution on that tool!
    I don't mind buying something vintage &chunky and restoring if needed but I'm after a real quality tool as I really like this kind of tool and I'm using it quite frequently,the nobex will go straight to dump after I get something better - so I don't want another saw from that manufacturer.
  2. When you say trim do you mean little delicate bits of work or large moulding? I recently saw a guy using a shooting board plane combination and the finish was excellent but the Veritas will set you back the better part of £300.
  3. Sponsored Links
  4. Roger928
    Roger928
    10 Aug 2016
    2,631
    Thanks Received:
    201
    Country:
    Hand sawing and the shooting board would be a better option.
  5. JobAndKnock
    JobAndKnock
    30 Sep 2011
    6,376
    Thanks Received:
    1,383
    Lancashire
    Country:
    About the only "big and chunky" hand mitre saws you'll ever find are the Ulmias (now defunct - the makers went bust about 10 year ago), which have a cast iron base, HOWEVER, they only have detents at 0, 22.5 and 45° and they won't handle compound cuts. I've had both an older Nobex and an Ulmia 352 and accuracy in the past on both was so-so on bigger stuff (because the blades tend to bind and squirm in deeper cuts) but very good for small section beadings, etc - their intended use. On all but smaller beadings it was generally necessary to fine tune the cut afterwards with a mitre plane and mitre clamp (or on site with a razor sharp block plane) which is probably when the Morso-type mitre trimmers became available they so quickly came to dominate the market. Either way this type of tool is not suitable for making large cuts (e.g. 3 x 2 softwood) for which a conventional hand saw and square with a hand plane to clean-up is the way to go
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
