Firstly. I have not had a really good look at this installation, but I will be going back.
A friend asked me to install an extra light in to her loft, no problem.
When I cam to connect the new cable to to ceiling rose I noticed the earth had been broken (turns out it had been cut off), so I naturally stripped it back and made a fresh connection.
I thought I would visually inspect the rest of the cable and connections, when I came to the switch I removed the cover and low and behold no earth! into or out of.
On I continued, the switch is fed from the switch on the landing, so cover off. No earth there either, I checked another still no earth.
I haven't yet examined the CU, she was in a rush. She has had an extension, about 3 years ago, so I would expect there is an earth in there, but the older part of the house has me worried.
The house I would put at about 50 years old.
Has anyone come across this before?, is there any reason this would be the case?
The back boxes are all metal the cabling does not appear to be T&E (except in the loft) but singles in appearance, on the lighting circuit it seems to be 2.5mm red and black insulation.
Any advice, I am very concerned for her as she is of an age now.
Her CU is new thou has been fitted in a vertical plain .
I will go back an examine in more detail, and take a few pics, in the mean time any thoughts
