Thermolite vs concrete block?
16 Sep 2014
Essex
Hello
I am currently converting my garage and replacing the garage door with a window and a the door. I have finish the foundation.
I called up merchants to make an order for blocks and bricks etc…. He asked me which block, thermo lite or concrete block?
I am not sure.
I am going to insulate the wall internally. The wall is literally just a 1 metre high with a width of 1.44m. The wall be rendered
Which is the best or which would suite my construction?
And the lighter 3.5N ones not the very heavy dense 7N. Deffo don’t get thermalite
Hopefully here we don't go again!
If it's still the same design as before (and your waterproofing issues are being dealt with separately) you should consider the heavier 7N blocks to add stability to your door/window arrangement.
hope it ends here
