Thin Tile Cut
20 Feb 2007
Cheshire
I'm currently fitting some large (450 x 310 x 8) ceramic wall tiles to a bathroom and have been using a standard large score and press style cutter.
The cutter has been fine until I need to do a thin (15mm) slice from the long edge of a tile.
Is it possible to use this kind of cutter for such a thin cut or is the only way to use a wet electric wheel type ?
I'm not the most experienced tiler on the planet but I don't like your chances of pulling off a 15mm slice. Over here you could take it in to trade places where they do difficult cuts for a price but I don't know what you have over there. I'm renovating a whole house and invested in a wet diamond saw. It's worth every penny (or cent) :wink: ...Kev...
Yes you can use a wet saw but I'd be inclined to use an angle grinder with a decent diamond blade (more useful than a wet saw set up). There's nothing to stop you using a straight edge with an angle grinder. With a decent blade it'll take you less than a minute for that cut. Start with a light cut along the straight edge, then go all the way through on the second pass.
i'm with gcol on this one. cutting on a flattened pile of wet sand makes life easier too.
I started off using an angle grinder but my cuts finish up about as straight as a dogs hind leg and the thinner ones seem to always break on me just as I get to the end :roll: ...Kev...
Hi, i would score the size you want and then score again at 30mm. Snap the tile at 30mm(it should break if you have a decent cutter) and then 'nip' off the un needed 15mm. Im a tiler and thats how i do it. Give it a try. Good luck.
my Rubi Tile Cutters...
would do the works for a ......DIY/Pro......BANg ..ON...
From a BOSS Tiler ...Rubi .....
BRILLIANT....lol :) ........you wont look back ....
the reason the manuel cutter won't work on thin strips is because it is crowned in the centre and the clamp needs a fare surface to apply pres
sue to ,a 1" strip is not enough .A wet saw is the way to go
crazycanuck
